How it works
Before getting started with Bootstrap’s modal component, be sure to read the following as our menu options have recently changed.
  • Modals are built with HTML, CSS, and JavaScript. They’re positioned over everything else in the document and remove scroll from the <body> so that modal content scrolls instead.
  • Clicking on the modal “backdrop” will automatically close the modal.
  • Bootstrap only supports one modal window at a time. Nested modals aren’t supported as we believe them to be poor user experiences.
  • Modals use position: fixed, which can sometimes be a bit particular about its rendering. Whenever possible, place your modal HTML in a top-level position to avoid potential interference from other elements. You’ll likely run into issues when nesting a .modal within another fixed element.
  • Once again, due to position: fixed, there are some caveats with using modals on mobile devices. See our browser support docs for details.
  • Due to how HTML5 defines its semantics, the autofocus HTML attribute has no effect in Bootstrap modals. To achieve the same effect, use some custom JavaScript:
const myModal = document.getElementById('myModal')
const myInput = document.getElementById('myInput')
myModal.addEventListener('shown.bs.modal', () => {
  myInput.focus()
Live Demo
